Please !! Anyone with a air intake kit COME IN !!!
So what you mean is that I should unplug the negative.........than start the car ?? but how can the car start without its battery ??
I am confuse....can someone just tell me in simple english what I have to do........Sorry guys....bear with the new guy
codes!!!
If u dissconect the negitve battery terminal from your battery for about 5mins. it will clear the codes in your computer. see when there is somthing wrong with your car (like a senser) the check engine light will come on.because the computer see somthing wrong. then u can plug in a code scanner into your car and the code scanner will read the codes from the computer and tell you whats wrong! ... is your check engine light on??
IDLE...........is which the rpm is at when you have your car in neutral or park. It should be at 700-850rpm.
