silvermsp said:Ok I want to keep moding my msp but I'm on a buget..
What other mods can I add... that aint that expensive ..
I have CAI, Motor mounts, Gauges, boost control, BoV,
What else can I add?
Thanks
kamon8404 said:Catless exhaust was the first mod for me, and it made a huge difference in pull and turbo spool. I would recommend it to anyone for bang for buck. I would check into the dsm afc, its only 390 shipped for the newest version and I believe 325 for the old version shipped; but you can find them used for cheaper often. I have read nothing but great things and plan on getting mind in Oct. if not, definately Nov.
vcinsanity1523 said:woah woah a little more knowledge here boost controller is no good without at least intake and exhaust,
I would def recommend an exhaust if you don't have one and at least hardpipes and an upgraded side mount intercooler or fmic before going anything over like 8-9psi
vcinsanity1523 said:woah woah a little more knowledge here boost controller is no good without at least intake and exhaust, the rest of the things you have are fine but how many psi of boost are you on. I would def recommend an exhaust if you don't have one and at least hardpipes and an upgraded side mount intercooler or fmic before going anything over like 8-9psi and with some sort of engine managament you could go for 10-12psi but remember our engines have really really weak rods so you shouldn't boost high like that also our LSD's are crap unless you have it welded. Good Luck
speed_addict said:im not super familiar with the LSD. What exactly does it do? Where is it? Why would it need to be welded?
vcinsanity1523 said:The LSD is what sends the power to the wheels of our cars by detecting wheel spin and adjusting power accordingly. Our LSDs always s*** the bed and need to be welding just like in these pictures in order to be able to put power down to the wheels without problems.
http://www.msprotege.com/forum/showthread.php?t=123628687&highlight=welded+lsd
A welded LSD can be seen with more information and can be purchased here
http://mazda3online.web.aplus.net/product_info.php?cPath=21_32_180&products_id=488
