plastic panel rivets
Iceman04503
2015 Mazda CX-5
I need access behind the front grille. If i drill out the rivets holding the plastic panel above the grille in place. What can i use in place of the rivets so i can have easier access the next time?
Or you could use ABS trim clips/screws of which there are myriad different styles. Here's an example:
I bought both the sheet metal screws and the abs trim screws. Ill try it out tomorrow and see which one works better. Thanks guys.
