kosteniuks17
- Mazda Protege5 2003
Wanted to let you know that the pinging on my P5 (145,xxx,2003) has stopped pinging. Not sure exactly how, but it was pinging a good amount when accelerating and then I seafoamed it. 1 bottle in the gas tank and 1 through the vac hose, then changed spark plugs to Copper NGK V_power ones, and swapped out spark plug wires. Anyways it went a way a little and came back. And I continued to look at other stuff to fix it, put 91 gas in, and now it somehow stopped all of a sudden, and its hotter now than before which always made the pinging worse. So anyways in case you have similar problem then try these things out. Ill prob change my oil soon, then clean the egr valve, and possibly later might change fuel filter. But I'm happy now!
