Pictures of the REAL autoexe grille (56k=death)
ssinstaller
2006 MazdaSpeed 6
Here are som pictures of the real autoexe grille. It is definatly much better quality than the erebuni copy I had purchased. You can actullay see where someone sanded the autoexe grille after it was gelcoated. It includes mounting bolts with the nuts molded into the fiberglass.
Better question: What's the price difference?
Erebuni Grill
I wouldn't say that the Erebuni grill is a cheap knock off just because it is cheaper than the Autoexe grill. I think that it follows with everything else. If you buy a cheaper body kit or c/f hood you will have issues with fitment and it will require more prep work, whereas if you buy the more expensive stuff it will fit better (not always perfect) and require less prep work. But that's just my .02.
