Mr. 4500 RPM
- Black P5
two tone eh? you should pant the hatch black too haha give it a full flow!
vindication said:yeah, also not knockin it, just givin you a heads up so if you notice it then you can take it to the shop sooner than later for them to fix it up.
told ya that tow hook was coming, cuz it looked sick on your ride! (sssh)L8R said:day pics! day pics! lol i love the tow hook
cant wait to see updated pics. looks pretty good though
peace
gino said:If you look at any new vehicle on a dealer lot, you will notice that front and back urethane bumpers aren't an exact match with the body color, in certain light. A straight-on view will usually show a close, if not perfect match. An angle view will usually show a color/metallic flake change because of the way the urethane accepts paint. This is also true with fiberglass.
This is because paint sprayed on steel or aluminum panels doesn't "lay" the same as the same same paint sprayed on, let's just say "plastic" materials. Even if a metallic color blends perfectly in certain lights, it generally will not blend in a cross-light. This is true of all metallics; it's the nature of the way metalflake settles onto plastics, regardless of primer color.
I got into a lengthy discussion over this with my bodyman who is a paint-match wizard. He attended an all-day class on this problem and how to deal with it. The best you can do is match the paint as closely as possible--exactly, if you will--and spray extremely carefully so that the metallic content in the base paint looks exactly like the original finish you're trying to match when seen in daylight dead-on.
And there will still be a slight difference. Don't forget, if you are doing two-stage--clear over color, the color will change--deepens slightly--when the clearcoat dries compared to the paint w/o clearcoat.
Been through this too many times to count...
RenzoMSP said:Idk is the hood a little off?
capnsavem said:oh yeah. stupid vis hood. piece of donkey s***. if it wasnt free.... hopefully i can get the gemini hood soon
haha yeah.WetsuitxNinja said:so thats why you wanted to borrow it eh, if you wanna check out the quality of it, im only bout an hour drive from you, or if there is a decent swell anytime soon ill be out ur way...
Joker_Fl said:looks good !
Johndg said:Better. Did you paint around the window trim. I like it better solid black. Whatever floats your boat. Did you trim out the cente bottom on the rear? Thats what it looks like. I got to see this in person.
