Pics of boost gauge
hectik1
Contributor
This is a Revo gauge. Don't have the blue LEDs on the cluster like the Grand Touring... YET!
With that being said here are the pics.
In the future I may do a little more with this to make it look COMPLETELY stock.
Thanks....A/C vent isn't really missed. Like looking at the gauge much better.
Another note: The ECU limits boost to 10 psi when the traction control is engaged.(protest)
stock.
You need to replace the instrument cluster to get the lumanecent gauges. $370-$380 discounted online.
offset_98 said:
I need to know how you ran it...I'll be doing an A-pillar add once they're out.
thats what i want to do as well, BUT ... side-curtain airbags...
FYI there are never airbags in the A pillar. The side airbag is in the front seat bolsters and the side curtain airbags comes out of the edge of the headliner. The SRS label on the A pillar is just a label. Gauges can be safely mounted on the A pillar.
It's interesting that boost is limited to 10psi with the TCS on.
But the TCS turns itself back on at 18MPH. Does the car build more than 10psi before 18 mph?
I believe boost is being limited when the TCS is actually intervening like when there is snow on the ground.
Actually, I have seen 14.9 or so PSI with TCS on or off. TCS does help the launch ability pretty significantly, however.
