Pics of AEM intake
Cookim6 said:
AEM intake off of 05 Mazda 6s sold to get the CX7. Cheap, easy, and it sounds good. According to the butt dyno mid and upper rpm power seemed to increase. Throttle reponse has improved also.
Fit is perfect!
just installed AEM intake for 05 Mazda 6s
but there is a small vacuum cap come with the kit, where should I put it?
and after I install the kit, the CEL show up, what should I do?
My standard CX 7 intake system draws cool air from in-front of the radiator. The picture of the custom system appears to draw hot air from the engine compartment. A'm I missing something ?
There is still cool air coming in from the scoop. The scoop and the lower part of the stock air box is intact.
wongster said:
so were you able to ever get a dyno?
Well I missed a free dyno....
With us moving into a house, and my daughter's first Bday I have had no time.
I think before I go I might do something with the muffler....(yes)
just installed the aem intake same one as yours this morning.. i can notice the pickup, and i can hear the turbo sound now.. hahaha... but i think i might make a custom heat shield to block the engine heat from the intake.....
Hey, just wondering if you can take pics inside your engine. I'm trying to figure out how'd you install the whole AEM system. Namely, the support bar for the pipe. I can't figure out a good place to bolt it onto the chassis because the intake tube is crooked when I attached the AEM pipe to it. Did you stretch the intake tube like crazy so that the support bar would bolt on properly?
