Pg Manifold Reference Point
merritt check your US Mail box today and let me know if a 6x6x6 package arrives for you. pm me when that happens, thanks sir.
back on topic. yeah people seem real hesitant to removing the valve cover. it really isn't that big of a deal, honestly, and there is no harm in doing it. if you are worried about contaminants getting to the cams or valves, i would use a plastic sheet or lay flat an unopened trash bag over the exposed head. once the manifold is sitting down where it needs to be you can put the cover right back on. it really only needs to be off for a few minutes at most.
You have PM.
OK i am posting the optimal solution photos for the PG manifold install with minimal modification and easy,simple make shift adaptation and no problem results.Car has been run and tested for 700 miles under hot climate conditions.
Just heat wrap manifold runner next to intercooler hose.
Shorten hose to minimum or max it out as seen and clamp as usual at very edges.Done no need to raise intercooler or get a big hose.No errors or complications or CEL as a result of it.
