I finally installed my manifold a couple of days ago. The stock manifold is a heavy mother too, easily twice as heavy as the new piece.
The biggest news about the install is that I didn't have to remove the valve cover. I didn't even need a pry bar or anything of that nature. After removing the studs from the turbo and the manifold bolts, it just slid right off. I don't have any real tips to offer, it's a fairly straight foward install. I already had my CS downpipe installed, and that made it easier to get to some of the manifold bolts. But on the flip side, the downpipe would have been easier to install with the manifold off. I didn't take many install pictures, there are good ones out there already... but here are a couple of the better ones:
I do have a fitment issue, but it is being taken care of.
The turbo seems to spool a lot faster, and is louder. The car hasn't adjusted to the faster spool yet, and I've been getting some boost spikes. The manifold is pretty damn awesome, if I do say so myself. I'm still running stock boost. 2nd gear is now useless to me, even tho I just put new tires on last week. Looking at my DashHawk logs, I have full boost by 2900rpms if I floor it at 2500. If I floor it at 3k, full boost is before 3300. Boost drops to just under 12lbs at redline.
Here's a couple of 4th gear pulls I logged with the DashHawk:
4th gear @ 3200ish rpm... boost spikes to 18.XX @ just over 3500rpm and falls to 11.xx @ 6400ish rpm
4th gear @ about 3250rpm... boost spikes to 19.5psi @ 3600ish rpm and falls to 11.5ish psi @ 6400ish rpm
