PCV Valve
Hey everyone
I’ve had an issue with rough idling for a little while now. I’ve seen on the forums that it’s a common thing so I’ve ignored it mostly.
Recently, I’ve started noticing high consumption of oil. And just yesterday, the oil light came on, and I can feel air coming out of the dip stick hole, meaning there’s a lot of pressure in the engine.
I’m no expert, but these seem to be symptoms for a clogged PCV valve. The valve is nestled under the intake manifold. Has anyone tried replacing one themselves, and does anyone have a part # for this?
Just an update, I believe I found the part. It comes as a kit, not a separate PCV valve from Mazda.
PWS3-13-570​
Still looking to see if anyone’s had luck changing this themselves
Upvote 0
