I took my car out on a 'moutain run' if you will today, and noticed a particular problem. The car seems to do fine at small throttle openings, and seems okay at WOT (if perhaps a little less responsive than it should be... its like it takes a second to 'kick in', aside from just the turbo spooling). When i do part throttle/part boost, ie if i wanted to keep it at a consistant 80% throttle opening which would keep around, for example, 4 psi of boost, it tends to start bucking alot. Its fairly annoying when trying to run the car near its limits, and i either have the choice of running poorly, not having enough power, or trying to cope with putting down more power than i'd want for the situation. Can anybody make any suggestions for what to do about this??
If its just a fuel delivery/ecu type problem, i've been working with unichip for months now trying to get that figured out....
