Pandora, USB, and Aux Disabled?
Hey guys just wondering you guys ran into this issue? It was working fine last week where the Bluetooth was automatically pairing with my phone and being able to even open the Pandora and Bluetooth tabs. Right now only the radio works. The other tabs are grey and I am unable to open the tabs.
Just wondering if you guys had any insight?
Thanks!
^^ Try disconnecting the car battery for a few minutes, that should clear it up.
If you disconnect the car battery, you need to reset your driver's auto power window up and down function by putting the window all the way down and then all the way back up while continuing to hold the button in the up position for an additional 2-3 seconds after it is fully up. You also need to reset the tire pressure monitoring system (TPS) by verifying that all tire pressures are at factory spec, then pressing and holding the TPS button on the lower dash to the left of the steering wheel with the key on and engine off until the TPS symbol on the speedometer bezel flashes. You may or may not have to reset the TCS, if you do, email me for instructions.
Thanks!
Nice picture! (naughty)
I had to take it to the dealer. They had to plug in and reset the software. Took them 4 hours to figure it out. lol
I tried taking the battery terminals off and it didn't fix the issue.
