Palm TX/Bluetooth
schaefrl
cx-9
Has anyone been able to get a Palm TX to connect via bluetooth to a 2009 CX-9? I've tried several times with no success.
I connected two different Samsung i760's with no problem what so ever.
Is the Palm TX TOO OLD??? lol
Have you ever connected your Palm TX thru BT with any other BT device?
If not, your BT chip on your Palm may need an update or is even defected w/o you knowing it. The fact that you have connected two Samsungs with CX9 tells me that the CX9 side is not at fault.
In early days, some implementation of BT was flawed. Very often than not, a firmware update to fix BT was needed. Check your Palm website to see if there is any update available for it. If you never used it, you would never know that there is a problem.
Curiously, the TX sees the Mazda but couldn't connect. Just tried it with the phones and a laptop. It sees all of them and conversely, all the other devices see the TX, but they don't want to connect with the TX. I'll keep trying and let you know what happens.
