good tip on the pressure when hot, these were shipped with 35PSI on them... I usually keep mine on 32 when cold for the street
Know what's scary? Emilio's responses can almost defend the crazy stretch bulls*** fad.
With the 205 Rival, it is good on a 7 and really good on a 7.5. And slightly better on an 8 (better feel).
The 225 Rival is ok on a 7.5", good on an 8, and freakin' magic on a 9.
I only mentioned it because the dyno sheet makes it looks like you're still building power when you hit the limiter. Might be worth upping the limiter to 7600 RPM if the engine can take it to see if power starts to taper off.Limiter is set to 7,495, took it close to that once. Problem is, stock turbo runs out of steam up top, it's can't hold 10 psi after 5.5k
Yes, I got my living room back. The tubes are support for the tires, the other two stack on top and are held by a rod. I can tie them down for extra safety, or I could have a tube welded in permanently to stack the tires. I only used 2 tires so I could take measurements for the fuel jugs.
Have 2 sets right now, but trying to sell one. Eventually I'd like to get the same wheels I have now (15s) with slicks, and keep driving the Rivals on the street.
Use up the Rivals then get slicks for the TRM wheels.
