I swapped mine out less than a month after buying my p5. The factory ones suck.
I grabbed a set of steel anco wipers and havent had any trouble since. They stick to the windshield at 75mph without getting any air under them or chattering.
Here is a little trick I use. Put some shiny tire goo on it and wipe it clean. It should moisturize the blade and make it repel water which will help it sweep the water away. Make sure you wipe it really clean though otherwise you will have streaky windows.
