p5 turbo problems
ghettobubba2001
Contributor
MP5
guys my car is experiencing fuel cut even even when its not cold outside, i have a p5 with a msp setup, msp turbo etc, fmic, and msp ecu. anyone think it could be the fuel pump? i am at 8 lbs
As always I'm thinking loose hose somewhere, it'll cause a boost leak but maybe not a vac leak. I drove around a week and didn't even notice that my hot pipe was about to pop off, I just assumed it was the MSP being itself.
I think it could be because of the msp ecu. When I had my boost controller, I got fuel cut only if the boost would spike above 10psi. You could purchase a fuel cut defenser from speedciruit.net for about $75. It take about 20 minutes to install. Or you could just turn the boost down.
^^ definitely, definitely don't get the fuel cut defender. That's not what it's made for, despite the name. It is to prevent fuel cut if you know you have a good tune and don't need the safety functionality provided by the fuel cut.
I've hit 8psi (when it's really cold outside) and never hit fuel cut that I know of. What does fuel cut even feel like?
Maybe if you had all your sensors you would be better off(bicker). Call Manuel, get the car fixed once and for all. Don't make it a more PITA then it already it....NIG.(hi) (boobs2)
No. Our stock pump and injectors are good for at least 200whp. quote by NSN and Ken ( P.G )
