MacProtege5
this didn't happen for quite some time, but it just keeps getting worse and worse, and now its at the point where i can't even drive the car. after the car is fully warmed it would feel like the engine was misfiring, it would buck a little then go away, and like i said it would just keep getting worse and worse. now i know my car burns a little bit of oil so i really think the cat is clogged up and its not allowing the car to flow out the exhaust gases. and i also got a code for the first 02 sensor signal being low. this is possible right? for the cat to be blocked not allowing the engine to run correctly? and possibly foul one or both of the 02 sensors?
