Well, it's pretty close to true with pristine plugs, which is what the link a few posts above this was testing. However in the real world crud builds up on the plugs unless they are kept at the right temperature (which is why heat range is important) and if the gap is too small that crud tends to short circuit the plug and result in no spark at all. On the other end, if the gap is too wide there may not be enough voltage in the ignition system to cause a spark to form. The plug gap opens up slightly over time due to wear (the spark is HOT and evaporates molecules off the surface of the electrode.) So setting the gap right is essential if you want the motor to run well for a long time.
My main point was that a little bit of resistance in the plug wires is irrelevant. The spark will form just fine if there are tens of Ohms (stock plug wires) or even as that experiment showed, much larger serial resistances. So the idea that getting rid of all the resistance in the wires is needed, or that resistances must match exactly, isn't supported by any experimental or observational evidence that has been presented in this thread.
