P2009 and P0660 error code questions
smetzger
03 P5, 09 Miata, 13 Fit, 09 Ody, 99 Civic
Got a CEL on my auto P5. Pulled the codes and I have P2009 and P0660
P0660 - That is most likely the VICS solenoid gone bad. Will replace.
P2009 - Is that most likely the VTCS Solenoid? with a possibility of and issue with the VTCS Delay Valve or VTCS Shutter Valve?
1) Is it ok to dive the car with these codes while I wait for parts?
2) For the P2009... Is this a good strategy for fixing... Replace the VTCS Solenoid with a known good one and clear the codes, if code comes back then issue is with the Delay or Shutter Valve?
