p0300 random misfire
black daliha
2003 mazdaspeed protege
I have a p0300 code wich is a random misfire i havnt had all these symptoms like other people have. I felt a chug like once while driving on the interstate I changed the spark plug wires and the coils have the same specs as a brand new one. Can anybody give me any idea what to look for it im not really feeling anything wrong?
k yeah i wanted to check mine i have some white markings on the ground strap of the plug and i cnt remember the part number but if they are not platnum then i need to swich to that
Can also be caused by a vacuum leak, leaking EGR or bad gas. You can also use copper plugs. OE NGK Laser Platinums are stock no 3271. I've been using NGK V Powers stock no 4291 ever since replacing the original plugs that came with the car.
I'd put in some fresh plugs gapped correctly and reset the pcm.
well found the culprit problem it is going into pre ignition wich meens more then likely carbon so i did the water steam treatment and will be putting in some carbon cleaner
