knowledge007
Banned
That depends are you cool with your dealer.
Its not about the business. Its about building a rapport with your dealer. Just as I have built one with mine. My speed is modded all to hell and They will take care of what ever I need.
Good luck.
you guys aren't gonna believe this, but the problem was fixed after i took out my CPE cai.. as soon as i turned on the car, CEL is cleared and no more jerking. man, i can't believe it.. im gonna have to call CPE directly and make a complaint. hopefully, they'll give me my money back or replace it with a new one. thanks for the help guys.
I had that code too and it was cause two of my injectors were bad. trust me it aint going to go away when you put the stock airbox on.
let us know what cpe says ... im curious
Wow, that is interesting . Please let us know what CP-e says. they seem to be a good company and imagine they will rectify the issue. Still, miss fire? Best luck!
Some how I seriously doubt the CAI would be the cause. Did you disconnect the battery when you uninstalled the CAI? If so, thats why your CEL has gone off, you have reset the computer. If you didn't then you could have seriously shorted out your car... Anyway, good luck.
did you do a checkup of your CAI after taking it out? it's possible that it's leaking/crack/etc.
It is possible that it had one misfire, then never had a problem again. Wouldn't the CEL clear itself if that were the case, after so many starts/days with no repeat of the problem? I still doubt your CAI caused a misfire, that doesn't make sense at all.
actually, i called CPE today and got in touch with some of the techs/engineers. they were very shocked to know that somebody actually had a problem with their CAI.. we did some troubleshooting.. they had me clean the maf, check the straightener inside the intake, and clean the filter. i did all but still no luck. the car jerks and stumbles when cruising..i put the stock air box on again, and no problem. they told me to come down to maryland.. so i'm driving down there from new york. hopefully something can be done.
