Attn: Common Mazdaspeed Problems & Fixes
Engine
<hr>Issue: Hesitation.<hr>What: A few of the members here like to occasionally "smash gas" from time to time. If you've ever done that and noticed that while at full throttle the car seems to bog down like it won't go any faster, then you've just experienced hesitation.
Why: Basically, what happens is that when you hit wide open throttle, the ECU switches to an open loop and dumps a HUGE amount of fuel in the mix. The car basically becomes overly rich and "floods" itself. As another member stated: "It is hard to notice an engine that is running lean to a certain point, mostly because it feels very powerful for the most part. Rich mixtures cause the poor drivability and hesitation. When the ECU switches modes it is going from lean to rich basically, which will make that hesitating feel..."
How To Fix: If the hesitation bothers you to the point where you want to drive your MSP off of a cliff, stop by your dealership before you do so. Mazda has released a flash which "cures" this condition. A flash is just a reprogramming of the car's computer and is available for FREE at Mazda dealerships. What it does is advance the timing to a point where the car leans out a bit more and gets rid of the too overly rich condition. Keep in mind that if you plan on adding a boost controller to your car, advanced timing is a bad thing and could lead to knock or detonation. Please think about your future plans before proceeding with the flash. It is *NOT* reversible unless you find another unflashed Mazdaspeed owner who is willing to trade ECU's with you. That is very hard to do, however. Mazda's official Technical Service Bulletin (TSB/M-TIP) is shown directly below:
TSB/M-TIP:
There's a list of more ECU information, including a list of notified dealerships, that may be found here.
<hr>Issue: Coolant Leaks.<hr>What: Checking under the hood, you may see a white residue on some of the stock piping or down on the brush guard under the car. If you do see this, that's coolant and it's leaking from somewhere. Check out the pipes and see if you can find the leak.
Why: Because Mazda loves us.
How To Fix: Return to dealer and show them where the leak appears to be. This will be covered under warranty in most conditions.
TSB/M-TIP: Not available.
<hr>Issue: Broken Intercooler Pipe.<hr>What: If your car sparatically idles or dies after boosting, you may have broken the intercooler to BPV pipe joint.
Why: Mazda used plastic piping for whatever reason it was but in the process, they decided it would be okay to glue the joints together instead of mold them. The stress of boost may cause the joints to break causing a massive vaccuum leak.
How To Fix: Return to dealer. Unless you've blatantly abused the car, most will fix without asking questions.
<hr>Issue: Airbox Duct Falls Off.<hr>What: Notice anything missing when it comes to your airbox? That small "L" shaped elbow may have come off during driving.
Why: That elbow is not attached to the airbox in any way and several members have reported losing it.
How To Fix: Duct tape, baybee!@# Actually, your dealership cannot do much about this one. They may replace it if you lose it but it's just going to fall off again unless it's secured.
<hr>Issue: Exhaust Comes Apart.<hr>What: While driving or idling, if your exhaust tone gets a bit louder or if it starts resonating in the cabin, your exhaust may be coming apart.
Why: As this has happened to just a few members, we really don't know for sure. This could be a combination of extreme heat and bad welding or just bad research and design.
How To Fix: If this happens, first check between at the weld between the primary and secondary cat to see if you exhaust did, infact, fall apart. This most likely will leave you stranded but should be covered under warranty.
<hr>Issue: Brittle Hoses.<hr>What:
There seems to be an issue with the wastegate/bypass valve hoses on some MSPs where they are very dry and brittle and may crack causing a vaccuum leak.
Why: Mazda used fuel hose for the majority of the tubing which means it's very brittle. Add this plus the underhood temps and you'll understand why they may crack.
How To Fix: Return to dealership and have them replaced with bulk silicone type hose.
HUGE thanks to the members here who I have obtained this information from.
Also, Thanks to TheMAN and his Protege FAQ for the Technical Service Bulletins.
<hr>ATTENTION: THE FOLLOWING INFORMATION IS NOT OFFICIAL IN ANY WAY, SHAPE, OR FORM. IT IS MERELY A COLLECTION OF COMMON PROBLEMS EXPERIENCED BY THE MEMBERS OF THIS BOARD. YOUR DEALERSHIP HAS THE MOST ACCURATE AND UP-TO-DATE INFORMATION ABOUT YOUR CAR AND IS MORE THAN LIKELY CORRECT IF THEY ARE GOING AGAINST SOMETHING WRITTEN IN THIS THREAD. DO NOT GIVE YOUR DEALERSHIP A HARD TIME IF THEY ARE REFUSING SOMETHING JUST BECAUSE YOU SAW IT HERE OR AT ANOTHER FORUM. TAKE THE ADVICE BELOW WITH A GRAIN OF SALT AND USE YOUR OWN JUDGEMENT AND THAT OF YOUR DEALERSHIP'S SERVICE ADVISORS' WHEN IT COMES TO YOUR VEHICLE'S SPECIFIC NEEDS OR PROBLEMS.<hr>Engine
TSB/M-TIP:
Code:
MAZDASPEED PROTEGE - HESITATION UNDER ACCELERATION
Applicable Models
Model Starting S/N Ending S/N
2003 PROTEGE 00000000 ZZZZZZZZ
Symptoms and Conditions
Hesitation and/or intermittent stumble under acceleration. All Mazdaspeed
Protege PCM's should be reprogramed using the following procedure.
Repair Procedure
1. Verify customer concern.
2. Using WDS B27.4 or later software, reprogram the PCM to the latest
calibration (refer to "Calibration Information" table) by following the
"Module Reprogramming" procedure.
NOTE:
* Always update the WDS PTU first, then install the needed calibration
file that the WDS shows during PCM reprogramming. Go to "WDS
Calibration" on ESI and download the "update" file. If the PTU is not
updated to the latest WDS calibration level, the calibration file will not
install into the PTU.
* It is not necessary to remove any fuses or relays during PCM
reprogramming when the WDS screen prompts you to do so. You may
accidentally stop power to one of the PCM terminals and cause the PCM to
be blanked, or you may receive error messages during the WDS
reprogramming procedure.
* WDS shows the calibration part numbers after programming the PCM.
* Please be aware that PCM calibration part numbers and file names listed
in any RI/Service Bulletin may change due to future releases of WDS
software, and additional revisions made to those calibrations for service
related concerns.
* When reprogramming a PCM, WDS will always display the "latest"
calibration P/N available for that vehicle. If any calibration has been
revised/updated to contain new information for a new service
concern/issue, it will also contain all previously released calibrations.
* When performing this procedure, if the WDS PTU is not docked and
connected to 115V-120V, we recommend that a battery charger be
installed on the vehicle battery and turned ON to a maximum charge of
no more than 20 AMPS to keep the vehicle battery up to capacity. If
you exceed 20 AMPS, it will damage the WDS PTU.
5. Place an "Authorized Modification" label (P/N 9999-95-AMDC-97) with the
new calibration information near the Emission Control Information label
located on the hood or in the engine compartment.
4. Verify repair.
NOTE: After reprogramming a PCM, it is necessary to road test the vehicle
to relearn KAM (Keep Alive Memory) strategy and verify no MIL
illumination or DTC's are present.
CALIBRATION INFORMATION
NEW PCM CAL. P/N FILENAME
3ALU-12A650-MC QOAP4C0
Copyright Mazda North American Operations
