wonkothesane
I have an '03 Protege5 with about 50k miles and recently it's started having an overheating problem. What I've determined is that the radiator fans don't come on unless the heater is on. When the heater is on, the car runs fine with no problems. I've already replaced the thermostat with no change in behavior. Has anyone come across this issue before? And if so, what was the solution? I'd prefer to fix this at home if at all possible...
Thanks in advance for your help!
