Overheating!! Coolant boiling in reservoir... Help!!
N0TyourMSP
2003.5 Mazdaspeed Protege
<div class="bbWrapper">I was driving for about 20 mins on the freeway and when I exited I heard some weird sound coming from the engine bay and noticed that my temp gauge was shot up almost to the very top. I pulled over and checked it out the coolant was boiling like crazy ! I didn&#039;t see any leaks. Any clue what this could be ?</div>
<div class="bbWrapper"><blockquote data-attributes="member: 88280" data-quote="N0TyourMSP" data-source="post: 6191480" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=6191480" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-6191480">N0TyourMSP said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I was driving for about 20 mins on the freeway and when I exited I heard some weird sound coming from the engine bay and noticed that my temp gauge was shot up almost to the very top. I pulled over and checked it out the coolant was boiling like crazy ! I didn&#039;t see any leaks. Any clue what this could be ? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> It is possible that you had to little coolant in the system which allowed it to get above boiling before the pressure raised in the system. You need to fill your system and allow the engine to warm up with the radiator cap off. looking down into the radiator you will be able to see the coolant level drop inside the radiator when the thermostat opens. Add more coolant at this time. If you did not get coolant everywhere when you opened the system it was defiantly under filled.</div>
<div class="bbWrapper">chances are either your thermostat is seized shut. and or maybe you water pump has failed. hard to tell when the water pump fails as if i remember correctly the timing cover covers it. but def check to see if your coolant is low. if its full and stays full and you dont see it circulating then, move on to either thermostat and lastly waterpump</div>
<div class="bbWrapper"><blockquote data-attributes="member: 111685" data-quote="jerseymods" data-source="post: 6191506" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=6191506" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-6191506">jerseymods said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> It is possible that you had to little coolant in the system which allowed it to get above boiling before the pressure raised in the system. You need to fill your system and allow the engine to warm up with the radiator cap off. looking down into the radiator you will be able to see the coolant level drop inside the radiator when the thermostat opens. Add more coolant at this time. If you did not get coolant everywhere when you opened the system it was defiantly under filled. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> Thanks man ill give it a try!</div>
<div class="bbWrapper"><blockquote data-attributes="member: 91825" data-quote="protege3690" data-source="post: 6191536" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=6191536" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-6191536">protege3690 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> chances are either your thermostat is seized shut. and or maybe you water pump has failed. hard to tell when the water pump fails as if i remember correctly the timing cover covers it. but def check to see if your coolant is low. if its full and stays full and you dont see it circulating then, move on to either thermostat and lastly waterpump </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> Thank you ! Ill give it a try and ill let you guys know what happens!</div>
<div class="bbWrapper">this should go without saying, but make sure the engine is cool before removing the radiator cap and when you twist the cap you should hear/feel pressure releasing before the cap is able to be removed. like 1/4 turn to release pressure and another 1/4 so you can pull it off. i know multiple people who have been sent to the hospital because they removed the radiator cap from a hot engine and it sprayed up in their face.</div>
<div class="bbWrapper">in addition to the thermostat and water pump, a cap that isn&#039;t holding pressure will also cause boiling.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 243" data-quote="njaremka" data-source="post: 6196954" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=6196954" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-6196954">njaremka said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> in addition to the thermostat and water pump, a cap that isn&#039;t holding pressure will also cause boiling. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>+1 Had this problem once and it was just the radiator cap. The small plunger piece on the bottom had broken off.</div>
<div class="bbWrapper">mine is suctioned into the rad, pulling it out is like trying to pull a plug out of the hose of a super powered vaccum cleaner.</div>
