Recently found out my overdrive button doesn't work so I got the manual out and did the tests the suggested found out that the continuity is good and that power is traveling through the wires up to the harness i'm assuming the actually button doesn't work?
Is this possible? Should I replace the whole shifter then or just forget about it ?
Any suggestions...
Thanks
Any suggestions...
Thanks
