Please put up something on youtube ..we need to hear that sawed off shotgun exhaust..
..I'm watching this thread every hourMAYBE tonight
Well my go pro keeps freezing and when it does work it only records for a few seconds so I wont be able to get the video clip. Sorry
Not sure the valving is any different from what I understand. I adjusted it one turn so far its good. Maybe one day I will take it off go for a drive then install it again and see whats what
Ahh, I was refering to the BSpec Bilsteins vs the PSS kit since the bar was developed with the bspec kit. I'm in the market for new suspension. This close to pulling the trigger on the PSS kit. (I don't think the bspec kit will be nice on hawaii roads...)
I just installed my tri-point bar and wow. If the stock shocks felt a bit overstressed from the H&R springs, they definitely are now with the bar. I might break out the toe plates and take measurements. I'm rolling around on 1 turn of preload too for now. Sunday will be the real test.
don't it would be a waste of money I got mine for free
don't worry I was thinking of getting it when mine wasn't doing well. My 2 is a GS (touring) so I got all the weight from the options it came with.
If I had money to own a second 2 it would be a base model, I would strip that sucker down to nothing and install a tuned MZR 2.0l under the hood. But thinking of that makes me think that I could own a used MX-5 instead I miss my 92 Miata soooo much
Did you cut the rear bump stops at all like I did?
Will you be there at the scca event this Sunday?
Miata now your talking!
