S Stealth5 It's SABOTAGE Contributor : 02.5 Protege5 Jan 30, 2005 #1 ok i got my teins and tokico whites installed and theyve been settling for over a month. the problem im having is with the rear, on the rear drivers side, theres a huge gap compared to the other side heres pics: why the hell is it like this?
B Brian MP5T Banned Contributor : MP5T / 944 Jan 30, 2005 #2 Upper Pilow Mount not aligned properly. Bolts caught on the frame...
S Stealth5 It's SABOTAGE Contributor : 02.5 Protege5 Jan 30, 2005 #4 Brian MP5T said: Upper Pilow Mount not aligned properly. Bolts caught on the frame... Click to expand... i dont think thats it...and where do bolts contact the frame?
J JOS3 Member : 05 22V mazda3 Jan 30, 2005 #5 jeremy, sorry to threadjack, but im curious as to how you like your avs es100's?
S Stealth5 It's SABOTAGE Contributor : 02.5 Protege5 Jan 30, 2005 #6 the only complaint i have with them is theyre a little too quiet at their limit, i like to hear my tires a little more when im pushing them
T toucci Member : '03.5 Proteg 5 Jan 30, 2005 #7 my espelirs are even on a flat surface but any sort of incline and they lean to one side about one half finger width
A ARD MP5 Member Contributor Jan 30, 2005 #8 Make sure the spring is seated properly in the strut's spring perch. For tires that make noise at the limit the Toyo T1S has a real nice howl. hehe.
B Brian MP5T Banned Contributor : MP5T / 944 Jan 30, 2005 #9 Stealth5 said: i dont think thats it...and where do bolts contact the frame? Click to expand... Upper Pilow Mount under the rear shock tower where the belts disapear into the plastic jobbie...
F Familia323 _______________ Jan 30, 2005 #10 what about the bump stops? would cutting those do anything? (<--OMGF*KNN00b)
