okay guys lets discuss
I like the way they look, but don't really see them being useful. I put the PIAA white LEDs in my parking lights, and those look cool and are a lot less. I don't like the idea of cracking open my headlamp personally.
i kinda agree with you... especially since i dont have much knowledge with that.... =/
Baking the headlights isn't really all that hard. People have discussed how to do it in various threads on these forums. I've never felt the urge to go that route and install a set of DDEs since it is a decent amount of work for nothing more than a mild visual upgrade, but that's just my personal opinion. I haven't heard any complaints about the quality or installation of them though.
hmm i dont know cuz it looks nice i just dont know if i want to mess with that
Putting something in the oven at low heat doesn't seem hard at all. I just don't see the worth in those. I'd rather spend that $100 on HID fogs, which will actually help you see at night. Just my $.02
sorry im a little new but what do you mean by the term of " putting something in the oven at low heat " or " baking the headlights " what do you guys mean by that because i have some soft of clue but i just wanna make sure that im right
anyone?
Baking the headlights is exactly what it sounds like. You remove the headlight housings from your car (make sure to disconnect all the electronics) and set them on a cookie sheet in an oven set to 200 degrees for about 20 minutes. This softens up the adhesive holding the front lens to the main housing so you can pry it open. May sound crazy but that's how it's done.
yeah. i baked my headlights in my old protege to change the sidemarkers out. it came out really well. the only thing you have to watch out for is if you don't get a good seal, you'll get condensation in the lenses.
To each his own...the money spent on DDE lighting can be used for the motor mount, shifter bushings, or put toward something more promising.
where would i find a motor mount and shifter bushings...
and dont mind me askin but what to those help up..
sorry yea i kno im a noob at this car. but ask me anything about an evo and ill be able to answer u lol i just never imagined gettin a ms6 lol but yea anyways......?????
Prepare for some info young grasshopper. If the Des Plaines listed under your avatar is Des Plaines, IL then I would suggest doing business with Protege Garage since they're damn near local to you. Even if you live across the country I still recommend doing business with them because they have an excellent reputation. There are a few other sites listed around various sections of these forums that can point you to them.
As for the parts and why you should get them, the stock rear motor mount has soft rubber bushings to reduce as many vibrations as possible. Unfortunately, this is accomplished by allowing the engine to flop around under the hood like a fish out of water (well, not THAT bad but still sloppy). The upgraded motor mount is either a urethane or denser rubber with a more substantial metal frame to help hold the engine where it is meant to be while driving. It really helps to eliminate those rough feeling shifts while accelerating since everything is lined up. You may feel a slight increase in vibration since the engine is now more securely attached to the car, but it's mild at worst. Most people only seem to notice it when the AC is on and generally only feel it in the steering wheel, it doesn't make your car feel like it's falling apart or anything terrible like that. I don't recommend anything over about 70 durometer stiffness since those have a tendency to transfer more vibrations.
I have not replaced my shifter bushings yet since I plan to do them with my short shifter when I start interior upgrades this spring. These replace the soft bushings under the shifter base plate (where the shifter attaches to the car, have to take out part of the center console to get at it) and reduce some of the unnecessary play in the shifter. The bushings are metal instead of rubber, or whatever soft compound they stuck under there, and are around $20-30 for the set... a worthy upgrade. Hope that helps some.
