ok quick question about motor mounts...
well im going to take it for a drive in like an hour and a half or so... wonder if it would make a difference... driving wise... ill see in a bit... just have to do something before i can check
ya, man, with 45psi, you will have a smaller contact patch than if you ran with stock (32psi) pressure, so you wouldn't grip the ground as well...=/ it will save you a little bit of gas mileage cause of reduced rolling resistance, but it will also be more likely to blow up on you when you go over a hard bump...:D
