Attention Chuyler, Poseur, Wake, 1sty, and others. I need your help with setting this up properly.
My goal here is to run a 3 way front stage (Rainbow Pro CS365) plus a sub (either Arc 12D4v2, or a/d/s 312rs )= 7 speakers total.
For the signal, I have an 8053 with hi/front, mid/rear, and low/nonfader to work with. For amps I have a MBQ 4 channel and the DLS A5 3 channel.
This is how I planned it out:
DLS A5---> front channels run tweets + rear runs sub
MBQ QAA4250---> front channels run 4" midranges + rears run 6.5" midbasses
My question: How do I put this together correctly if I only have 3 channels off the HU, but need to run 4 in the system?? Can I split the R and L on the mid/rear preout with a Y splitter for both sets of mids? I was thinking of running the tweets off the hi/front, band passing both mids and using the x-overs on the MBQ, and running the sub off it's channel. Please tell me where the errors in my thinking are here.<O
I also plan to run the 8053 16v balanced with the BLA, so I don't know how that affects using an electronic x-over if one is needed. If I do need one, which one do you suggest<O
</O
<O
Thanks for your time(thumb)
John
<O
<O
John
<O
