Oils, Coolants, Fluids
Keatonc
2001 Mazda Protege MP3
So, final post, I replaced the engine in my MP3 with the same but newer. Which fluids, what type, how much, and HOW do I replace them. I know there is a lot of coolant that needs to be replaced, and engine oil of course. But I am confused on the clutch fluid? and the transaxle fluid? or are they the same. Also, how do I fill it back up? thanks. And any other fluids that need to be replaced (except window washing fluid) thanks!
See if there is a Haynes manual for your car. That will have all the fluid amounts and what type is recommended.
Search in the how to for gear oil. Clutch fluid come from the master cylinder, same as brakes. Engine oil, fill it up till its full on the dipstick and then add a half quart to that.
If you have to ask questions this simple how did you do a motor swap on your own? Not trying to be a dick just curious
Lol, I somehow pulled it off. I had the haynes manual but It honestly didn't give me any help. But thanks guys, i think I figured it out.
