Oil on PCV ??
NorthernP5
2002 Silver P5
P5'ers,
I own an 02 P5 with 82000 kms (50000 miles) on it. This past weekend, I was checking oil, filter, belts... and dicovered that the oil level was down (about 3/4's to full on the dipstick). When I checked my PCV valve there was an oily residue on it.
-Its been about 2000 miles since my last oil change. I use Mobil 1 5W30.
-changed my plugs about 1000 miles back.
Is the residue on the PCV valve normal? Is this a sign of bigger problems?
Any help is most appreciated!
pcv valve (Positive Crankcase Ventilation) releases pressure that builds up in the head, so seeing oil there is ok, since you got ~50k miles just to make sure go replace its only like 5$ or so,
