normandy2013
Hey folks so I have a pretty big oil leak. Every use of 1 or 2 full tanks I have to add 1 quart of oil, which is about every 300 miles per full tank, or once every week or week and a half...
It looked like I needed to change the valve cover gasket which I did
Before Pic:
After replacing the valve cover gasket it was much better, as well as performance, but I see the rubber blue seal starting to give, and also the black rubber seals where the nut goes in...its only on the side where the valve cover cap side is, and no I do not spill oil when adding it...
Why does this happen do I need a stronger or thicker valve cover gasket? Is it the heat or what?
After Pic:
Before Pic:
After Pic:
