Oil Filter Guide
biking4jesus
2005 Mazda3 Hatch, 2014 Mazda6 Touring
Wanted to drop a post that lists all compatible oil filters for the new 2014 mz6.
remember its 4.8qt w/ filter change, or 4.5qt w/out filter change 0w-20 for US models.
Mazda PE01-14-302 (about $8 at dealership)
K&N HP-1008
Wix 57002
Fram PH6607
Bosch 3300
Mobil M1-108
Notes about the size (based on fram site)
Product Height 2.63"
Product I.D. 20mmx1.5mm Th'd
Product O.D. 2.69"
Relief Valve Setting PSI 13
Gasket I.D. 2.27"
Gasket O.D. 2.53"
Gasket Thickness .2"
Gasket Usage Base
K&N HP-1008
Wix 57002
Fram PH6607
Bosch 3300
Mobil M1-108
Product O.D. 2.69"
Gasket I.D. 2.27"
Gasket O.D. 2.53"
Gasket Usage Base
MikeM in the SKYACTIV ENGINE OIL REQUIREMENTS thread indicated the PE10-14-302 filter on the SKYACTIV engine is a special high flow filter,and even though it is the same size as the Mazda filter on the Mazda2,you should not use the one for the Mazda2 on the Mazda6. Since many of the filters you list are also the ones listed for the Mazda2, I wonder if they meet Mazda's high flow specs for the SKYACTIV engine.Maybe someone can research this and put all the info in ONE thread for SKYACTIV engine oil filters.
