Be advised that most current engines' need for shorter OCIs stems from damage to the oil from fuel dilution. If you're not monitoring your oil through analysis, you're a blind person making a WAG estimate in the dark.
As to 5W20 vs. 5W30 in these engines, volumes of hard data show lower wear with the 5W20, so there's no argument over what works and protects best in this app.
