oil catch can installed
MS3 GT
ms3
installed my simota oil catch can today, everything was done pretty straight. after start the car up, i realized my ABS and TRACTION CONTROL light is on, reset the battery and still on? anybody know whats going on????
ABS and traction control use wheel speed sensors. Did you move, break, disturb or unhook anything there when getting at the PCV valve hoses and lines and positioning your catch can? Just a thought.
Hopefully you used a check valve so that boost pressure from the manifold is not getting back into the PCV side as well. Check other catch-can threads. You should have those lights on. A vacuum leak still seems to be on the table since nothing electrical is involved in a catch can, unless you disconnected something electrical during the install.
