UPDATES! SOFT AWR bushings in!
Well, I froze my ass off and got the softer bushings in the rear mount. Was amazed when I fired it up. No more harsh bouncing of the car when it starts, the rattles are GONE, that horrid resonance when you hit around 1500 rpm is GONE, Idling in nuetral with the heat at full blast and the headlights and radio on vibrates at least half as much as it used to with no accessories on. I can now drive less than 40mph in 5th gear without being deafend by the resonant vibrations. Heck, I was going on a slight incline in 5th @1500 and it wan't loud OR vibrating much more than stock.
There are still some vibrations. The 1100-1500rpm is still there, but barely noticable compared to the harder bushing. The steering wheel and dash still shake at idle. BUT it's so much less than before. NO MORE RATTLES!!!!!
Oh and I only installed the softer bushing on THE REAR! Still have the hard ones on the front mount! If you love the AWR mounts but can't stand the vibration spend the ~13 bucks and get two of the soft bushings for the rear mount!
(headbang)
(mj)(dance)(nana)(yes)
Yes I'm Friggin HAPPY about these bushings!
EDIT: Just to clarify things:
I had the AWR manual mounts in prior to this. I now have the hard (manual) bushings in the front AWR mount and the AWR mount has the softer (automatic) bushings in it.
Manual mount bushings are 95 durometer
Automatic mount bushings are 88 durometer
UPDATE 1
Fired it up cold this morning. Little more vibration than yesterday. Still much better than the 95's. The steering column rattle is still there, so I'm going to pull the cover off and put some foam tape in there. I'm happy that 95% of the unbearable rattles are gone. The door panel rattles are gone, the resonations are gone.
I'm going to put the 88's in the front mount tonight and see how much more vibration is get's rid of. I'm still impressed with the reduction in vibration so far.
UPDATE 2
I just swapped the front bushings. Now I have more vibration! I think part of it is that the bushings need to break in. The other is that the way the front mount is sitting, since there is adjustment on two planes, is placing more wieght on the rear mount and causing more vibration. I'll know tomorrow when I put some miles on it.
UPDATE 3
Well, the vibrations from last night are gone. Car is even smoother than before. I noticed that I CAN SEE CLEARLY IN MY MIRRORS!!!!! They aren't vibrating at all! The idle-1100rpm vibe is still there, but even less. Above ~1300 the car is as smooth as stock, but still has the more solid feel of the mounts.
(headbang)
UPDATE 1
UPDATE 2
UPDATE 3
