Antoine
Administrator
The Mazda3 MPS (Euro version of the MS3) specs have officially been released!
* Click on the pic for more info!
The Mazda3 MPS is outfitted with Mazdas 2.3-litre DISI Turbo petrol engine
in a front engine, front-wheel drive (FWD) layout that produces more than
184 kW/250 PS at 5,500 rpm and maximum torque of 380 Nm at 3,000 rpm.
Six-Speed Manual Transmission and FWD
These are the converted euro specs for us "Americans". Thanks to Rogue Pro5.
power: ~184kW (250ps) @ 5500rpm (EEC net)
power: ~247hp @ 5500rpm
torque: 380Nm @ 3000rpm (EEC net)
torque: 280 ft/lb @ 3000rpm
fuel requirement: 98RON (93[R+M]/2)
fuel requirement: premium unleaded
fuel consumption: 9.7l/100km (ECE)
fuel consuption: ~24mpg
emissions compliancy: EuroIV
0-100km/h: 6.1s
0-62mph: 6.1s
50-100km/h (in 3rd gear): 4.2s
31-62mph (in 3rd gear): 4.2s
80-120km/h (in 5th gear): 5.4s
50-75mph (in 5th gear) 5.4s
spring rates:
(front): 33N/mm
(front): 188lb/in
(rear): 30N/mm
(rear): 171lb/in
stabilizer sizes:
(front): 26mm
(front): 1.02 in.
(rear): 25mm
(reaf): .98 in.
Chassis rigidity has been upgraded, and suspension has been upgraded to have 60% increase in body roll stiffness.... flared front fenders are used (20mm wider than non-MPS models)... speedometer range has been increased to 174mph (versus 143mph on non-MPS models) but vehicle speed is ECU limited to 155mph... front disc brake size has been increased to 12.6 in. (11.8 in. for non-MPS "sport" model, 10.9 in. for others)
Look to MZSPD3.com for the latest MS3 specs, info and discussion!
(drive)
