Obx header is complete!
alprotege said:
does this header comes witht he o2 sensor holes pre installed?
it has a bung for the 02 sensor to plug into, but you have to wire up a MIL/CEL fix which is not hard at all.
might still fail a visual inspection however....if they see that a cat has been removed, they may fail you, even if it passes a sniffer....
im not really up to date on the e-check resources...how do they check odbii cars then?
so how would a header affect this type of scan? is it just reading the results from the o2 sensors? or is it coming from somewhere else?
if theres and MIL fix, is that gonna f-up the scan?
not really worried...just curious.
the mil fix will trick the o2 sensor into thinking its all good so no code will be thrown.
about the headers
i installed obx headers on my mp3 but my check engine sign is on how do i get rid of it do you know how to by pass it
when ever i speed up and someone is behind me they said that smokes comes out of my exhaust, thats just the exhaust from the car because there is not cats right?
help!
Allright-first off I'm a girl that has no idea what you are talking about. Why am I here? Husband just put header in his 2001 MP3, CEL has been on for months. Did not pass PA inspection and is driving me nuts b/c he can't drive his car. He has explained to me that with the removal of cat. con. the sensor that picks up engine temp is not reading a high enough temp and that's why it didn't pass. He wants to rip everything off the car and put it back to factory. In an effort to save the car I decided to see if anyone else had a prob with the sensors and how to fix it. However I do not understand anything that you suggest to the other people. I'm doing this b/c my husband does not use computers so once I get an answer then he'll read it. Thanks for any help in advance.
yeah, were generally a very helpful bunch. so if you have more questions just keep asking and someone will answer....(RTM)
