OBD2 faults all over the place?
2017 CX3 AWD
Folks, are we not supposed to scan for codes while driving? I am getting a long list of codes in the OBD Scanner ELM Pro app. None of them triggered a CEL. Nothing comes up once the engine is off.
Here's a list saved from one of the drives. Don't know what to think when something is stuck on and off at the same time. What exactly is wrong here, the app, the device, the car, or me? 😬 Please, let it be me, I am easy to fix.
Car Scanner ELM OBD2
Version: 2.1.14/22001014/GP
DTC report
Connection profile: Mazda SKYACTIV
Date: 3/22/2026 10:09:15 AM
VIN: JM1DKFC79
OBD-IIOBD-II
DTCs: 38
P050A(00) [0x050A00]
Idle air control (IAC) valve, cold start - performance problem
Status: Test not completed during this operation cycle
P050B(00) [0x050B00]
Ignition timing, cold start - performance problem
P0421(00) [0x042100]
Warm up catalytic converter, bank 1 - efficiency below threshold
P0456(00) [0x045600]
Evaporative emission (EVAP) system - very small leak detected
P0171(00) [0x017100]
System too lean, bank 1
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
P0172(00) [0x017200]
System too rich, bank 1
P2119(00) [0x211900]
Throttle actuator control (TAC), throttle valve - range/performance problem
P2101(00) [0x210100]
Throttle actuator control (TAC) motor - range/performance problem
P2107(00) [0x210700]
Throttle actuator control (TAC) control module - processor fault
P2109(00) [0x210900]
Throttle position (TP)or Accelerator pedal position (APP) sensor A - minimum stop performance
P0461(00) [0x046100]
Fuel tank level sensor - range/performance problem
P0069(00) [0x006900]
Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - correlation
P2199(00) [0x219900]
Intake air temperature (IAT) sensor 1/2 - correlation
P0711(00) [0x071100]
Transmission fluid temperature (TFT) sensor - range/performance problem
P0667(00) [0x066700]
ECM/PCM/TCM internal temperature sensor - range/performance problem
P0736(00) [0x073600]
Reverse gear - incorrect ratio
P0746(00) [0x074600]
Transmission fluid pressure (TFP) solenoid - performance or stuck off
P0751(00) [0x075100]
Shift solenoid (SS) A - performance or stuck off
P0752(00) [0x075200]
Shift solenoid (SS) A - stuck on
P0756(00) [0x075600]
Shift solenoid (SS) B - performance or stuck off
P0757(00) [0x075700]
Shift solenoid (SS) B - stuck on
P0761(00) [0x076100]
Shift solenoid (SS) C - performance or stuck off
P0762(00) [0x076200]
Shift solenoid (SS) C - stuck on
P0766(00) [0x076600]
Shift solenoid (SS) D - performance or stuck off
P0767(00) [0x076700]
Shift solenoid (SS) D - stuck on
P0771(00) [0x077100]
Shift solenoid (SS) E - performance or stuck off
P0772(00) [0x077200]
Shift solenoid (SS) E - stuck on
P0773(00) [0x077300]
Shift solenoid (SS) E - electrical
P0819(03) [0x081903]
Transmission gear selection switch, upshift/downshift - correlation to transmission range (TR)
C0001(1A) [0x40011A]
TCS Control Channel "A" Valve 1
P0040(08) [0x004008]
Oxygen sensor signals swapped, bank 1 sensor 1/bank 2 sensor 1
Status: Test failed, Test failed (current drive cycle), Test not completed during this operation cycle
P0040(17) [0x004017]
Status: Pending, Warning indicator requested
P0040(06) [0x004006]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
P0050(0C) [0x00500C]
Heated oxygen sensor (HO2S) 1, bank 2, heater control - circuit malfunction
Status: Pending, Confirmed, Test failed since last DTC clear
P0050(27) [0x005027]
Status: Test failed (current drive cycle), Test not completed since last DTC clear
P0050(18) [0x005018]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test not completed since last DTC clear
P0050(45) [0x005045]
Status: Test failed, Pending, Confirmed, Test not completed since last DTC clear, Test failed since last DTC clear
P0050(C1) [0x0050C1]
Status: Test failed, Test not completed during this operation cycle
Engine control unit
No DTC found.
Transmission control unit
No DTC found.
ABS control unit
No DTC found.
Dashboard
No DTC found.
BCM
No DTC found.
Steering
No DTC found.
Access system
Access system
DTCs: 1
B13D3(16) [0x93D316] Archive (inactive)
Status: Confirmed
SRS/Airbag
No DTC found.
4WD
No DTC found.
Multimedia
No DTC found.
Now that you have a record, I would clear the codes with the car OFF and scan again.
You may hold the record for the most codes at one time!
Good luck
Good luck
I saved the list but didn't clear the codes while driving. They just went away on their own. The one for access system is saying that my key fob battery is low. Other apps (OBD Auto Doctor & Piston) didn't find any DTC. I can try a different dongle tomorrow. 😳
After reading about how dongles are sensitive, I put our dongles on a one year battery replacement. January is replace the dongle batteries and even the old style key batteries for my 20 year old truck. Get them all changed and take that off the table.
Got to love how complicated Mazda made our dongles. Does the case really need to be that complicated with so many parts. It goes against the understated interior. It's almost comical.
That DCL list would get my attention too. Glad it cleared and wasn't an ECU failure.
My 20 year old truck has been quite a teacher. It taught me to go ahead and replace know wear items before they wear out. Or be prepared for it if I wait. At 230k miles it went through a period when many items were replaced or repaired. I did 80% of the labor. Now at 290K it's been rock solid. I'll treat the Mazda the same way. I'll pick the time and place to replace know items down the road.
