Hello all,
So I've had the cx-5 for a 1.5 months now. The mpg hasn't gotten any better. The last time I filled up it was 19.9 mpg. Believe me, I've been taking easy on it and my wife also drives very slow. Yes, it does drive in local traffic half of the time but I've seen people posting even with local they are getting much better mpg than me. With that being said, I noticed a few weird things recently. It's not "too consistent" but I have noticed it happening. Keep in mind, I had multiple manual transmission cars in the past so I know all about rpm, when it shifts yadda yadda. Today, driving home, I was about to exit the highway, it was going at about 55 mph and the rpm was at 3,000 rpm (so I guess it's probably on 4 or 5th gear). I let go of my foot from the gas pedal COMPLETELY so it can coast a bit before I brake and exit but for a good "I would say 2 or 3 seconds" the rpm was at 3,000 rpm. For ANY AUTOMATIC, it should of up shifted to 5th or 6th so it dropped it back to 2,000 rpm or so to save gas. Other than today, I've noticed in the past too that when I get my foot of the gas, the RPM hangs for a bit before it up shifts. Now, if it does this often, this may explain "one of the reason" why I use more gas than others even when I've been trying to break it in and driving like a grandma.
Is that how the automatic is? Or it's a bit unusual that I noticed the rpm hangs around before it up shifts? Perhaps cx-5 automatic has rev-matching???
The last few days I've been going in and out of highway and the avg mpg has been pretty much stuck at 21+ no matter how I drive (fast or slow).
Thanks...
Your transmission is operating as designed. I does have rev-matching for shifts. The following text is from the Mazda CX-5 Service Highlights page 871 :
AAS (Active Adaptive Shift) mode operation
Accelerator pedal fully closed suddenly and returned
When the accelerator pedal is fully closed and returned at a certain speed or more, shift-up is inhibited for
specified time to improve speed control and reacceleration performance.
Brake is strongly depressed
When decelerating at a certain speed or more, a lower gear is selected so that re-acceleration is
performed smoothly.
During a shift change with the brake pedal depressed firmly, blipping control (synchronization to engine
speed) is performed to shorten the shifting time.
When cornering
While cornering at a turn with a radius of less than a specified value, shift up is suppressed to improve
vehicle speed performance while cornering and reacceleration performance after cornering.
During high degree of vehicle ascent/descent
During a certain level of vehicle ascent/descent, gears are selected appropriate to the driving conditions
for driving comfort.
During ascent
While ascending a slope of a certain grade or more, slope mode control prevents unnecessary shift-up by
maintaining the appropriate gear.
During descent
While descending a slope of a certain grade or more and depressing the brake pedal, the gears are
appropriately shifted down according to the estimated slope angle for effective use of engine braking. As a
result, frequent brake pedal operation is reduced.
