D dhart2010 Member : 2006 Mazdaspeed 6 Apr 9, 2012 #1 My car hasnt been runnning right, so I hooked up a scan gauge to see what was going on and at wide open it barely made 8lbs, I'm not sure what is going wrong. Any help would be much appreciated!
D dhart2010 Member : 2006 Mazdaspeed 6 Apr 10, 2012 #3 It doesn't have anything done to it, I've only had it for about a month..
R repthemazdas PS! Banned Potential Scammer! : 99 protege Apr 10, 2012 #4 loose hose, try checking all hoses or waste gate somthing is leaking of stuck open!
D dhart2010 Member : 2006 Mazdaspeed 6 Apr 10, 2012 #5 Okay, I'll double check all the hoses and connections tonight
S speed666 Member : 2006 ms6 Apr 10, 2012 #6 when you say it hasnt been running right, what does it feel like? and how is it differant then a month ago when you got it, how many miles on car?
R redspeed6 Member : Mazdaspeed 6 Apr 11, 2012 #7 what kinda fuel you running?? if your not running 91+ - computer will pull timing and open the wategate to allow low boost to prevent knock
