Noisy front suspension
i'm sure there is more than one place to get them... but i got in trouble for mentioning the website i used. try doing a search, the fronts are 25mm. or you can PM me and i'll give you the top secret info in a cryptic puzzle.
For those of you replacing your front suspension's sway bar endlinks - where the hell do you get the nylon lock nuts that you use to bolt them up? I cannot seem to find them anywhere in the M10 1.25mm size thats needed for the endlink. Do you guys use a substitute instead?
standard bolt and some locktite will have the same effect...
Ok so I was playing with my endlinks and I just noticed that one endlink is easier to move around than the other. Would this have an effect on the car if I were to put them on?
