So where do I start? Need some input here.
I have 46K on my car.. Get an oil change between every 3-5K. The most recent oil change I did get was about 2,000 miles ago.
Well driving home from work yesterday my car started to make some really weird noise- sounded like a broken fan or something. Then all of a sudden my oil light came but it was flickering as if it was lose connection.. I stop at the nearest gas station to check my oil.. I was completely out of oil.. I had to put in 4 qts. I am not due for another oil change for about 1000 miles..
Why wouldnt my oil light come on sooner as a warning why only when its completely empty? Anyways.. I got some oil in it.. took it in to Jiffy Lube because it is now 8 at night (mazda is closed) I asked for an oil change (just to be safe) and for them to look at it.. they see no oil leak.. Could I possibly be burning that much oil?!! Jiffy lube did change my oil last also.. could they have possibly not put enough oil before??
What will cause your car to burn that much oil? I am sure there is no way to go back to Jiffy Lube and find out if they did put in enough oil last time..
I just hope I did not do much damage to my car.. I am taking the car in on Sat to get looked for that now and also other things.. my engine has been making a knockin noise now for awhile.. when I first got the car Mazda did warranty work on the engine .. I dont know a lot about cars at all.. but I guess Mazda broke the lower crankshaft bearing and I guess just the head gasket and valves. And something about the cylinder block. Could this be anything to do with it even though its down the road??
hmmmmmmmmmmm
hmmmmmmmmmmm
