Hello,
Ok so I purchased my 07 CX-7 in January. Just turned 106k. No problems until now, died while driving. Apparently previous owners/repair shop did not put lock tight on the crank bolt when they worked on it (whatever they may have done). Crank bolt backed out separating the 3 washers behind it. Replaced the crank bolt (as it is one time use only) and the 3 washers behind it with new. Vehicle had remained in time, chain was still in place, tight and all marks in place. Also used the special timing tool to hold the cams in place during repair. So all back together. Now I have Cylinder 1 Misfire code. Replaced spark plug, checked ignition coil (switching out with another ignition coil, misfire did not follow). Also I do have spark. Next step was compression test...Cylinder 1...0 psi :'( Cylinders 2, 3, and 4 all have 150ish. Cylinder 1 has NONE. So I'm thinking bent valves? I have rough idle and horrible ticking which was not there before and I'm assuming is the valves possibly bent in just the right position that they are still trying to move a little? Just my luck. Any ideas what my next step is? I'm thinking pull the head but I want confirmation first. Thank you
