I have a 2010 CX9 and just replaced the brake booster. Now brake pedal has no pressure. I pump the brakes several times and no pressure builds. I tried bleeding brakes and hardly and fluid comes out. So I then took the master cylinder out and bench bleed it, hoping that was the issue. However, It did not fix it. Still no brake pressure when I press the brakes.
Any idea what could be wrong? Any guidance is appreciated.
