does anyone know anything about this or have this?
i've seen it for the Dodge srt-4 before. how helpfull is it?(killit)(freak)
These things will be torque monsters on the juice!
no offense, I guess I should keep this opinion to myself but spraying NO2 outside the engine is a waste of Nitrous Oxide, I know it will cool the charge and so on but that sh@t is too expensive to be blowing out in the open air. With the hundreds of dollars that you will be spending on something that you have to keep replenishing you can certainly spend on something that will make your car permanently faster. But if you are rich and or you are running low 10's and just want to get a 9 second timeslip then go ahead.
You guys don't realize what damage you are going to do to the coil packs, and valve cover. Also, That kind of cooling is going to cause contraction cycles on the aluminum and steal valve cover/head that will show up as premature leaks and cracks. Stick with ice water sprayer resevoir for a TMIC.
um...i have no worries. i have a FMIC remember !!!
i'm a post *****, so let me post a pic of it again !
stock internals ? you mean, trimming the bumper, etc... ?
nope ... didn't trim much of anything.
just relocated several things ( recirc hose, a couple vacuum hoses we shortened, etc...)
