new wheels/tires on speed3
xxshark
07 mazdaspeed3
just picked these up today, let me know what you think. $1100.00 out the door.
unless you are lowered, those look like 19s. Definitely looks good!! Watch out for potholes!!
SSMS3 said:
Looks good!
What size wheels/tires, offset, etc?
225/35/20 tires
7.5" by 20" 45 offset motegi rims and not rubbing one bit. the only thing i noticed it seems to brake slower.
xxshark said:
225/35/20 tires
yup, I would be a little more judicious while driving spiritedly. Those rims prob weigh significantly more than stock which will affect acceleration, braking, and cornering. Alot a little more space to stop from high speeds. To offset, I would consider getting a new brake pad with a more abrasive compound. Hawks or Porterfields would work great.
they weight 25# a wheel. stocks are 24#. I've pick up both today there very close in weight.
*nod* however, with larger rims the weight is moved more towards the outside of the wheel, s the effective weight increase (what you will feel) is a bit more than the 1lb general weight difference. 1lb of unsprung rotational weight ends up being much more in practice.
Truth!
Also, the tire is more toward the outter most point of the wheel affecting rotational mass the most. Wheels look great anyway!
20"s, thats crazy of course your going to need more room to stop and plus you will have more rubber to cover for speed. Would never go above 19 but hey I have to admit, it does look sick...
Nice... best looking wheels I've seen yet. Heres my question though, can I install the Mazdaspeed coil over kit with these wheels?
What do you guys think?
