new rx-7?
would be a stupid move on Mazda's part.... with the RX-8 and all. unless they want it to compete with the likes of the NSX and upcoming Supra... which I suppose is a possibility.
rumor it is it will be coming out late 2005, with a turbocharged 330hp mazdaspeed version to follow. of course rumor also said that might be a picture.
Actually It will have the RX8 name plate. They will have a coupe model and convertable coming out. Next year half model. I will print the article from the magazine. I will get it from work today. Mazda is retiring the rx7.
Fe Rx-7
Mazda is most certainly not retiring the RX-7 nameplate, nor will it compete with the RX-8 (that car has created a niche of its own).
The FE-model RX-7 will be a two-door two-seater GT car, possibily also available as a convertible. It will be naturally aspirated and Mazda is working towards higher displacement (as opposed to turbo / turbos) to keep underhood complexity simple (ever looked at the vacuum lines under the hood of a FD-model twin-sequential-turbo RX-7? This means they're working on the long-ago still-born 15B or 17B projects (1.5L & 1.7L respectively) as opposed to the RX-8's 13B-based Renesis (1.3L).
The NC-model Miata will be out of the blocks at the 2005 Geneva Auto Show, to be introduced at the end of the year as a 2006, or possibly spring 2006 as a 2007. The RX-7 should be shortly behind that.
Mazda hasn't released anything about the looks of the new RX-7.
That still doesn't stop every magazine around from speculating about(and publishing"spy shots" of) it!
that prple thing is an rx8 with a body kit and ther 2nd ones an old rx7 with rx8 front end
No, the purple one is an RX-7 with a RX-8 front end and the red one is a computer graphic. :)
